That looks correct to me.
Yes but regardless of if they work or not. The circuit is built to turn on asymmetrical and symmetric clipping. It would be nice to have the label matching. Knowing when it’s on or off could be valuable.I meant to comment here earlier but forgot: I'm pretty sure that DIP switches are really, really dumb switches. They work in either direction because all they're doing is either connecting (on) or disconnecting (off). Doesn't matter which side ON is on because that side is always ON and the other side is always OFF.
As to why PCB graphics make them look like they have a direction: I don't know. My guess is that's just the standard way of picturing DIP switches.
As I said, when it's set to ON the circuit is connected, whichever way the switch is installed.Yes but regardless of if they work or not. The circuit is built to turn on asymmetrical and symmetric clipping. It would be nice to have the label matching. Knowing when it’s on or off could be valuable.
No need for apology. And knowing what the numbers refer to also matters, so your question is still valid. I have the impression that the numbers go over the white dots, so the opposite way to your pic. But I'm no expert, and I'm failing to find anything conclusive via Google.LMAO, noooooow I get it… they‘re on/off so who cares ! The only difference be will sw1 vs sw2… sorry I’m an idiot. For some reason my brain was thinking on/on…. Sooooowwwwy !
That’s ok, if I look at schematic, base on how I installed the switch would you agree that 1 is Asym and 2 is Lift ?No need for apology. And knowing what the numbers refer to also matters, so your question is still valid. I have the impression that the numbers go over the white dots, so the opposite way to your pic. But I'm no expert, and I'm failing to find anything conclusive via Google.
EDIT: This thread says white square = off, and a search of images of Paragons and Paragon Minis shows that most people are installing their DIP switches that way. If you look at the attached Paragon PCB, the white squares are at the bottom, which implies that the numbers go at the bottom and that up is ON - otherwise they'd be upside down.
Now, as stated they'll work correctly either way, ON is always ON - but setting 2 is actually setting 1 and vice versa, if the switch is mounted the opposite way.
Assuming the schematic and PCB are consistent, then I would agree. But to know for sure, use a continuity checker to see whats connected to what on the PCB.That’s ok, if I look at schematic, base on how I installed the switch would you agree that 1 is Asym and 2 is Lift ?
I guess I’ll be able to spot it by ear. If I get this right the lift switch turns off the clipping completely, so that should be obvious. Which leaves me with the other switch turning on asymmetric clipping. Unless I don’t understand what lift does….Assuming the schematic and PCB are consistent, then I would agree. But to know for sure, use a continuity checker to see whats connected to what on the PCB.
Or just use your ears to verify.
Thanks, revised my list.With "Lift" open and "Asym" closed you actually have one diode in one direction and three diodes in the other.
This is off the Frost.Which PCB is this?
And I would guess open is “on” right ?From the schematic, it appears to have 4 possible settings:
- symmetrical with 2 diodes clipping each way (lift closed, asym open)
- asymmetrical with 2 diodes one way and 1 the other (both closed)
- more asymmetrical with 3 diodes one way and 1 the other (lift open, asym closed)
- lift (no clipping) (both open)
Ok so switches are like alarm clocks, when the alarm goes on you say it went off !Closed is "On".
