Caldo71
Hey guys, so…
I have this Golden Falk that I built, and it sounds great…FRIGHTENLY like a real Plexi…but it has this funny specific issue:
It sounds perfect for about seven minutes of play through, and then this random crackling noise starts slowly entering the sonic landscape….first very faint in the background, then eventually becoming much more loud and prominent over the next few minutes.
Mind you, the overall tone of the pedal never degrades…it still sounds great…but it becomes unusably crackly/noisy.
So then if you power it down, and wait a few minutes, then power it back up…same thing. Repeatably, every time.
I’ve carefully re-flowed all the solder points just to make sure, and swapped out some of the “easy” components like the 3-way switch, pots, and tried swapping out the J201s which are socketed. Same thing still happens.
Before we get into the whole “show me photos of your build” thing, I’m just curious: does the fact that this issue seems to go away after the power is cut…and the pedal left alone for a few minutes…imply a specific kind of component failure?
From the very little I know about the mechanics of passive components, this sounds like a “capacitor thing” since they are supposed to slowly drain their charge after powering down…but maybe I’m being ignorant.
Thoughts?
Thoughts?
