iamjackslackof
Hi all,
Round two of a failing Echo Foxtrot built. My previous one would work for 30 seconds to a minute, and then sounds would fade out and stop altogether. If I pulled the power and waited a minute or two and tried again, it would start the process all over.
I just got another Echo Foxtrot board in today, and built it again. Same fade out issue exactly...
My guess is that the cheap Amazon L7806 voltage regulator I used on both. I had old docs on the first go round and it didn't mention it, so I had to scramble to get one in time to build it, instead of wait for another order from Tayda. I *think* they have a built-in shutoff mechanism if they get to hot.
My plan now is to get a new oneL7806, not from Amazon, and hope that that fixes the issue. I am still a bit concerned that it's happening at all though, since if it's happening because it is too hot, clearly there is some issue. If a different L7806 doesn't shutdown, is it because it has better heat tolerance?
Mostly posting this to vent lol. Here's hoping a new regulator will work, and if anyone has battled this issue as well, please chime in.
