Dumb this down for me (Audio Probe) I'm confused
swelchy
so If I wanted to build an audio probe to work in conjunction with my signal generator how do I build one ? I want to connect my signal generator to an audio probe built into a scrap enclosure and then run out into a little practice amp I have.... problem is I'm confused on what to connect and where?.. I have a spare enclosure.. some jacks.. capacitors and an extra set of multimeter probes to use to poke around with? Can someone sketch out or explain how to build one and where to connect everything?
A signal generator goes into the input of a circuit and an audio probe is on the output, so they are separate things.
Here is my audio probe. It is just an extension of the amp cable
Edit: I forgot to show another alligator clip from the cable ground to circuit ground
Yes, separate things but you can house them both in the same enclosure because they can be used in conjunction with each other.
Alas, the DavidMorrin site is no more so no link, but...
DPM me if you want the PDF of the above David Morrin pages.
Ok:
Better:
You can build either of the above two probes with the cap tucked away inside the plug's housing.
@jwin615 had the genius idea of reconfiguring an automotive tester to be an audio probe:
1000005547-jpg.84345
An old probe from a DMM is another option that's a step above using the lead end of the capacitor to probe with.
So...
SIGNAL GEN > CIRCUIT INPUT (or a looper pedal, or strum strum strum strum...)
AUDIO PROBE > AUDIO-DEVICE (headphone amp & headphones or guitar amp or radio speaker, computer speaker in etc...
Proceed to probe the circuit, poke the probe tip to component leads/solder-nibs along the audio path, you will get audio through the listening device up to the point you have a failed component / broken trace / whatever's wrong.
I like to bounce back and forth between the beginning and end of the circuit because it's a PITA to probe all the way from the beginning only to find the problem is at the very end and vice versa. Like eating a sub-sandwich by taking an alternating bite from each end until you reach the middle and it all falls apart...
@swelchy, this PDF from GuitarPCB is pretty durned good:
Very good, as well:
Oh, and PPCB, too, why not...
Took me forever to get around to probing because it seemed ... I don't know, above my skill level or something.
It's FAR easier than you'd think. Now I usually just use my Protoboard Mini for all the connections and a long jumper wire for the probe, throw the board or pedal on/next-to the mini-breadboard and feeding it with a looper or some music from my laptop.
It's PROBING time!
Ah... makes more sense now.. for some reason I thought the probe setup would be in front of the pedal... I was thinking backwards.... I think I got it now..... I built a dud this week and it's time to troubleshoot because everything looks spot on and I'm getting absolutely no signal when switched on...
So...my preferred method of doing things is to make things as difficult as possible.
So I haven't built an audio probe: I've built fifty.
Once for each time I need to troubleshoot a circuit. Jack? Check. Jumpers? Check. Signal generator? Check. Cap of random tenths of a uF value? Check. Muttering to self about pain in the ass goddamned piece of fuck...? Check.
...body bag? Check.
A small added point - also you may want to set the output level of your signal generator to match that of your guitar output, which you could measure with a high-impedance ac voltmeter. Rough expected range might be 10s of mV to perhaps 100-200 mV for high output pickups. This way you will measure behavior of the circuit in accordance with how it would act when connected to your guitar. This is particularly helpful when used with an oscilloscope, to see where distortion appears within the circuit (when using sine waves) and/or where equalization occurs (by using sine waves w/ different freqs, or when using a square wave signal), etc.
This is basically the approach I take when I’m troubleshooting at work (maintenance Electrician is my day job) -
Divide the circuit in half, figure out if the problem is in the 1st or 2nd half, then keep dividing it into half sections until you locate the fault.
For audio probing, I just record a little strumming into my trusty old EHX 2880. It’s (slightly) less annoying than listening to a continuous sine wave or whatever;)
Yeah, I flooded you with info, sorry 'bout that — but you never know what "clicks" 'cause everybody learns differently.
CyberCow's post for the win. He did as you requested, showing how SIMPLE a probe could be.
However, just a pic of the apparatus doesn't show the "how" — which is why I included some vids.
The probe itself replaces the lead/cable to the amp, don't even plug anything into the output jack:
