giovanni Well-known member Jun 14, 2023 #1 I see that the 220uF caps are used as part of the charge pump circuit so I assume they need to be 35V or even 50V? Can’t use those 10V I have lying around I assume…
Betty Wont Well-known member Jun 14, 2023 #2 The c20 caps only see 9v. They are power filtering before the charge pump. You should be fine.
DGWVI Well-known member Jun 14, 2023 #3 It's only seeing 9v, but best to go at least 25v rating. Also, it doesn't need to be 220u. I use 100u in that spot because I have a billion of em
giovanni Well-known member Jun 14, 2023 #4 Ah good call, I’m gonna use what I have handy then. Can I go up, like 330uF?
giovanni Well-known member Jun 14, 2023 #5 A silly question in hindsight, I could’ve figured this out myself!
DGWVI Well-known member Jun 14, 2023 #6 giovanni said: Ah good call, I’m gonna use what I have handy then. Can I go up, like 330uF? Click to expand... That will make your supply line sound like it has a wet blanket over it But, yep 330 will work as well
giovanni Well-known member Jun 16, 2023 #7 I ended up using some 50V 220uF caps I had that are large, but fit just right.
