Duocast spec'd capacitors
dmp
The pcb and build doc specifies 5mm, 35v capacitors in 330uF, 120 uF, and 100uF
I don't think these exist in that small a diameter?
I guess you have to kludge in a larger diameter cap.
I have this PCB too and wondered the same thing. I haven’t gotten the recommendation enclosure (1590BmM/Gorva S90) to measure it. I was going to check some of the build reports to see if anyone mention it or I could see the caps. I also wondered if a tantalum cap would be smaller and work.
Lame
It would be nice if the designer considered the availability of components when making a layout.
Even a little experience in electronics and you'd know not all electrolytics can be 5mm
Ok, here you go, did your research for you.
I found the blue Matsushita ones after I made the newbie mistake of ordering the Nichicons without checking the size off Amazon:)
So as a person "with very little experience in electronics" I was able to find a solution pretty easily.
Here you go, Ross @StompBoxParts has them.
But as mentioned, the big honking ones fit too...:)
This design has a DC voltage of 27v, so I would not use a 25v cap like that blue one.
Even the miniature Nichicons are 8mm, not 5mm. But no need to keep debating it.
Nice that the layout will be revised.
When I get the board I'll figure out the best thing to do with what will fit.
Post a link to that 5mm cap please. I tried a reverse image search and it didn't lead to any suppliers
I'm not sure about suppliers, I just know that they exist. I've seen them as high as 1000uF in similar footprints.
8mm will easily fit with absolutely no interference from adjacent components.
8mm Pananasonic FC (105C) caps fit pretty well, from Mouser, these are 35v or greater other than the 47uF (25v)
EEU-FC1V121BJ
EEU-FC1H100L
EEU-FC1E470
EEU-FC1V101
EEU-FC1V221LB
EEU-FC1V331LB
