thesoundofjusticefx
Hello brain team,
I am getting more of a bitcrush sound with the chorus mode with really low volume. The tone is very flat mid focused as well. When switching to vibrato mode there is no modulation, only the preamp sound. Same tone problems. I’ve made a couple of mids like the faster rate, unity mod, gain boost in the preamp (trimmer) and subbing 2n3904 for the lamp driver. The lamp pulses as it should and the bias and gain trimmers work with the lamp as expected. The LDR is 9203. So I’m suspecting a possible bad transistor. But my main question is does anyone have voltage references at the transistors or other bias points? Thanks.
