thesoundofjusticefx
- Build Rating
- 5.00 star(s)
I finally figured out the issues and finished up this build. It's amazing how fine tuned the bias, gain and dry and wet signal mix resistor sections are. I ended up making some minor adjustments to tweak the gain and bias easier and I did the effect (dry/wet) mix trimmer to get a slightly deeper swoosh and throb. I did the input unity mod as well but put it on dip switch so I can go back and forth because I found that fuzz pedals more to my liking with the original input impedance. There's a couple other tweaks I made from digging over some older schematics of the honey vs shin-ei versions and other forum findings. And then the photocell distance to the lamp was super important too. I even tried two different homemade light box covers (one reflective and one white) producing very different results. There are so may key areas of this design that add up to the final univibe sound. I definitely want to make more but I need a break, lol. This think consumed my life for a little while haha.
