Hi - I'm trying to understand better how the modulation on the EQD Space Spiral/Dark Rift Delay works.
Basically I think that the LFO provides a voltage at the other end such that the current draw from Pin 6 decreases at certain peaks across the LFO.
However when I measured the LFO with my oscilloscope with the Depth turned all the way up I got a square wave from 0V to 5V. What happens at 5V? i.e. Wouldn't a current flow into Pin 6 change things since current is supposed to flow out of Pin 6? Can someone confirm these readings please?
Thanks!
Thanks!
