F ferdinandstrat Member Jan 13, 2020 #1 So I installed all the drivers, multiple versions of them in fact and still this error occurs. It is driving me nuts. I connected both the 9V power and the USB
V vigilante398 Authorized Vendor Jan 17, 2020 #2 I went through about 6 versions of the drivers before I found one that worked. The one that ended up doing it for me was a 2009 version. Upvote 0 Downvote
A azerty_guitar New member Apr 1, 2020 #3 vigilante398 said: I went through about 6 versions of the drivers before I found one that worked. The one that ended up doing it for me was a 2009 version. Click to expand... Can you give a link ? thanks !! Upvote 0 Downvote
A azerty_guitar New member Apr 1, 2020 #4 I've post a link that work for me here : https://forum.pedalpcb.com/threads/fv1dev-pcb-error-connecting-ch341-1.1805/ Upvote 0 Downvote
Z zgrav Well-known member Apr 1, 2020 #5 also -- sometimes it helps if you manually uninstall the driver that is not working and reboot you PC before installing another driver. Upvote 0 Downvote
