Yeah, that does it! It has the round fatness that a lot of the others lackATF Brush from 2015 is the best digitization of it out there. Full ligatures and several weights. And its on Adobe Fonts to boot
Yes and don't even think about using AlgerianAs if I didn't have enough to worry about excluding/including stuff in my pedal builds — white-washers, neat wiring, perfectly conical solder-joints with even level clipped leads — now you lot are telling me I've gotta manually tweak the keming and ligapertures in my Comic Sans labelling ... ?
JesterPfft... Just use American Typewriter and be done with it.
That looks right to me. There seems to be some vertical compression along with the horizontal though. Have you tried Eurostile Compact Bold Condensed? Microgramma doesn’t have lowercase btw.Ampeg SVT front panel. What font is it?
It looks like Eurostile or Microgramma only slightly compressed?
I've tried Eurostile Bold Condensed - the letters are too thick. Here in the example above I have Eurostile LT Std Extended 2 with a 0.2mm outline.That looks right to me. There seems to be some vertical compression along with the horizontal though. Have you tried Eurostile Compact Bold Condensed? Microgramma doesn’t have lowercase btw.
Gotcha. Good point about the weight. Give Std Condensed a shot if you have it. The extended is stretched out and what you’re essentially working against with the horizontal resizing.I've tried Eurostile Bold Condensed - the letters are too thick. Here in the example above I have Eurostile LT Std Extended 2 with a 0.2mm outline.
I know it doesn't have lowercase letters, but Microgramma D Extended does.
Anyone know what Mountain is set in here? I'm on too big of a microdose of psylocibin to have any desire dive into a rabbit hole on it or clean it up enough for auto id lol
Bumping this ID request. Any help appreciated
https://fonts2u.com/descant.font ?Bumping this ID request. Any help appreciated
Sebastian Bold looks nearly perfect if you can nip off the serifs.Anyone with super Sherlock Font skills who can tell me what text this is:
I think it's the resolution of the available photos giving me trouble but I cannot seem to find a good match on the Font Finder sites.
