Fingolfen Well-known member Sep 3, 2022 #1 Any chance of getting a Fulltone OCD V1 board that could do the various V 1.X versions? Upvote 2
Robert Reverse Engineer Sep 3, 2022 #2 Sure. We used to have one before upgrading to the V2 circuit. I'll see about dusting it off and cleaning it up a bit.
GizzWizzKing Well-known member Sep 30, 2022 #7 I am kinda excited for this because 1. Almost every guitarist I have played bass with had one of these & 2. I've never played through one so it will be fun for that to happen.
Robert Reverse Engineer Oct 1, 2022 #8 Here's the plan, so far... Rather than create two separate projects (ADHD and ADHD Classic), I figured I'd just update the ADHD project... It's in dire need anyway. I've split the Effect and Enhanced Bypass into two separate modules. If you want to build any of the V1 versions you'd use the main PCB and pair it with a standard 3PDT breakout board (or hardwire the footswitch) If you want to build the V2, or V2 GE version you'd use the main PCB paired with the Enhanced Bypass module.
swyse Well-known member Oct 1, 2022 #9 Will the build doc be like the muffin where it has the various versions listed?
Robert Reverse Engineer Oct 1, 2022 #10 swyse said: Will the build doc be like the muffin where it has the various versions listed? Click to expand... Yep, that makes the most sense.
Robert Reverse Engineer Oct 15, 2022 #12 ADHD Overdrive - PedalPCB.com Compare to Fulltone OCD www.pedalpcb.com Improved Bypass Module for ADHD Overdrive - PedalPCB.com Buffered Bypass Module www.pedalpcb.com
Robert Reverse Engineer Oct 15, 2022 #14 This is the slide switch for the internal Buffered/True-Bypass switch on the "Improved" Bypass module. Mini Slide DPDT - PedalPCB.com DPDT switch www.pedalpcb.com
Robert Reverse Engineer Oct 15, 2022 #16 As soon as they get here. The switches are here, they just have to be counted.
B benny_profane Well-known member Oct 15, 2022 #17 Robert said: As soon as they get here. The switches are here, they just have to be counted. Click to expand... 42
Robert Reverse Engineer Oct 15, 2022 #18 benny_profane said: 42 Click to expand... Pretty sure there's quite a few more than that. I wish it was that easy.
