Fuzz Foundry... no sound.. again
Gefell
So I've build 20-25 pedal pcbs at this point.
The Fuzz Foundry was on of my first builds, it never worked so I tossed it. Built another 20 Pedalpcb circuits successfully, went back and just built a fresh Fuzz foundry... once again this doesnt work.
When engaged there is no sound at all, regardless of knob position. Ive verified transistors are seated properly.. Im totally stuck. This circuit is (on paper) the easiest build I've done... yet failed at it twice... WTF am I doing wrong on this one?
Any/all help would be amazing.
Heres a pic.
Do you have an audio probe? It will help determine where your signal dies out.
How sure are you the transistors are good? Are these the same ones you tried in your first attempt?
I think Buddy's right, next step is audio probe.
Upon closer inspection, the LED is a great start, and I bet it doesn't light?
I'm pretty sure the anode (+) is the smaller side, and the cathode (-) is the larger side (unless it just looks that way in the pic). (y)
