I read somewhere the + side of the electrolytic should always point at the nearest transistor.
That may or may not be a good rule of thumb, but there are always exceptions to any rule.
People seem to be hung up on a mythical limit to 1µ for box-film, and anything bigger will have to be electrolytic. NOT TRUE.
Because I play bass, I like to use
2µ2 Box Film caps often where only 1µ might be required for guitar.
There are box film from
Wima that go up to 4µ7 and available from Tayda.
Kinda handy for builds like Rats, where the cap after the op-amp is a 4µ7 and that 1µ at the end I've replaced with a 2µ2 while experimenting. Can't remember the final value I put in my build.
Also good for some Muff versions that have 10µ couplers, you can run two of those 4µ7 in
parallel to get 9µ4, close enough to 10µ.
Great for the "white can" Ram.
Some would argue that you can't hear a difference between electrolytic and box-film... Find out for yourself, make your own decision on that
— just make sure the difference isn't the difference in value of the caps. Compare a true measured matching value to each, these things have bigger tolerance drift than metal-resistors after all and depending on brand, batch and whatever can be out by up to 20% — even the big Wima is 10%. So that Wima could be as big as 5µ17 while the electrolytic being compared might be on the low side of 10% at 4µ23.
Comparing 5µ2 vs 4µ2, depending on their function in the circuit, you'll likely hear a big difference!
Let's say they sound the same, my argument would be still for that big box film, or tantalum, as from what Ive read electrolytics don't last as long. Just make sure the electrolytics and tantalums are oriented correctly +/- or the magic (&smelly) smoke will be released.
