Delaystomper
hi , so I purchased the fv1 dev pcb, but there are no build docs. yet are there going to be posted anytime soon ?
also can the board be used with spincad ?
If you look at the silkscreen on the board, all the values are labeled.
I don't believe that the board directly interfaces with SpinCAD but you can export the asm file and load it onto the EEPROM.
I recently finished my dev board (build report coming soon).
I haven't used SpinCAD but I've been able to flash text code onto the pedal. (Txt file in the spin language, then converted to hex in the SpinAsm software, then converted to binary with the Cmd lines, then flashed to the pedal using the AsProgrammer software - it's a lot of steps lol).
For learning/messing around, I've had an easier time downloading and editing people's source code (like from the spin semi site free programs, people posting on the spin semi forum, babel fish, etc). These have the originators comments and variable assignments, which makes it much easier to understand what's going on.
There is a Windows program floating around on the net called "CH341 Tool"... It supports HEX and BIN right out of the box (read and write).
You can completely cut out all of the conversion / command line stuff.
I don't link to it here because it is (allegedly falsely) flagged as malware. I can not confirm this, so use it at your own risk...
But with that said, it's what I use with my FV1Dev PCB... It's also the software that comes with those cheap $2 EEPROM programmers on eBay.
How is that dev board working any issues ? Mind shining some light ? I recently started populating mine and also cleaned up my old PC. So i cant wait to finish it and get startedI recently finished my dev board (build report coming soon).
