ridgedchips
I recently built the FV-1 Development Kit, and it powers on and pass dry audio through the volume/mix knobs just fine. However, whenever I write code to the EEPROM and the try to play guitar through it, all I get is that dry part of the mix. The build itself is neat, and there's no noise or other weird phenomena to guide troubleshooting, so I'm at a loss for what issues to look for. I'm using the AsProgramming application from the PedalPCB wiki, and whenever I export code from that program to the EEPROM, it always writes it successfully, since I'm able to read the EEPROM over USB with no issues. I've tried it with several different FV-1 algorithms I've found online, but the result is always the same. So I can't tell if it's a software or hardware issue. Anyone know where I should start troubleshooting?
