So I just found out today Tayda has a quick order form for parts if you have the correct item numbers. I'd like some help filling it out, I don't think I have the time to complete my list in a timely manner. If anyone is interested in helping out, please continue reading.
Before anyone asks, I already contacted Tayda, they do not have a spreadsheet with all the item codes available to share.![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Would have made my job a lot easier. Unfortunately, the only to do this is to manually search for the parts one by one and copy the SKUs manually into the spreadsheet.
I'm trying to make a similar form to the one I use for Mouser where you can copy the pdf info from the pedalpcb BOM and boom, your cart is ready to go.
This is the form I use currently for Mouser - I've added a second page for Tayda.
Here is the Master parts list that needs the Tayda codes for parts. Very partially completed.
Notes on which parts to select:
For the mouser parts list, I used the parts recommended by AionFx (the template is originally modified from their BOM spreadsheet), so it was easy enough to decide. For Tayda, I'm not always sure on the best part selection - especially for caps. See below:
Resistors: I've used the high quality ones -1/4w, although I know some use 1/8w, I haven't included the smaller ones
CAPS: For Tayda, I'm unfamiliar with the film and electro cap brands. I used Wima on mouser, but Tayda selection of Wima is very limited.
Generally I want to put the best ones available and try to have them valued at least 35v in case 18v power is available without a charge pump. I haven't run into space issues yet on pedalPCB boards going up to 50v on caps.
More than one kind can be included, but I need to decide on a nomenclature when the form looks up the value. i.e. C1 1uf-35v, C1 1uf25v, etc... No spaces can be used or it messes up the lookup filter when copying from the Pedalpcb PDF BOMs.
ICs: Tayda has much more limited stock than mouser, so there's usually only one available of each. This is probably the easiest one to finalize.
Diodes & Tantalum Caps: same as above
Pots: I've put 6.35mm Alpha pots whenever possible, they're not all there, especially the larger values and dual gang. *Watch out: Tayda has seemingly the exact same pots with and without dust seals, for the same price. I've put whenever possible the ones with dust covers.
Switches and misc.: I am going with the SPDT switches Tayda has marked "Tayda Highly Recommends - Quality Guaranteed " with the longer throw.
If I think of anything else, I'll add it in another post, but I'm interested to know if anyone else thinks the work is worth pursuing.
