Hi, all. I am working on an effects loop pedal (of my own) and I want to add a foot switch that can shunt the input signal to ground. When it's on, though, I want to light up an LED. For maximum headroom in this circuit, I am supplying 24VDC, so I need to add resistors. Ohm's law tells me that I need a 11.1k resistor which seem hard to find, and very expensive when I find them. So, if I run a trace and inline it with a 3.6k resistor (which would be a good value if I ever want to make a smaller version and run it on 9VDC) and then run that trace, in parallel, to all of the switches, and then use a 7.5k resistor at each of the LEDs, should that work? With Ohm's law, what I am not sure about is the current with the other items on the board. It seems like, as long as the other things aren't draining the current so much that there isn't enough left for the LEDs, that it shouldn't matter, and that the values I plugged in are correct, but I just want to be sure.
