Hi Guys! Long lurker and builder, first post! Maybe someone can help me figure out the wiring, or if its even possible, using SPDT, 3/4PDT, etc as needed. I am wanting to build an Octavia style circuit (already completed) and have the footswitch switch between fuzz (default, octave connection disabled) and octave up (octave connection enabled). Thats easy enough. However I also want to add a switch so that if its engaged, one direction will operate the footswitch as described, but if the switch is flipped I would like the footswitch to act as bypass when flipped. So in the end you either have the ability to enable/disable octave over fuzz, or when switch is flipped, footswitch between the effect and bypass. Thanks in advance, let me know if this makes sense or any questions!
