How is this board meant to be used?
DDad
I have the crappiest board ever, unless I just can't figure out how to use it. None of the holes are connected, and the solder pads on either side are not connected to anything. How is this meant to be used? I think this is in the running for crappiest board ever.
I cut my teeth on strip board (tagboard effects site) and it’s still my preference. But, cutting the breaks with a drill bit is kind of annoying. the EE guys at my work prefer perfboard and using the extra leg as the trace like pictured above. Effectslayouts.com is a whole site of perfboard layouts, so I guess he prefers those.
AKA protoboard. As in prototype.
OK, so plated perf board is a thing, but it's pretty fugly to me. You just lay down the legs of the components to make the connections, right?
Yes, or you can use wire for longer runs. Solder it into a component adjacent hole and then bridge to the component.
One advantage is you don't have a bunch of conductive surface.
I think you can also stick pot legs directly in the board I think? Or at least more easily than with stripboard. Of course it's personal preference whether that's better than off-board wiring, but for me, off-board wiring is the worst part of the build process, so while I haven't used perf board to build anything (yet), that is something to consider.
Perf-board — it's got far more logical flow with layouts (like a one-sided etched PCB) than the insane scattering of components across vero aka stripboard.
None of the holes are connected because you get to decide what's connected, without having to cut notches out of vero (I guess that's why they call it "stripboard", that or you want to strip yourself of every hair on your body trying to follow a schematic with vero-layouts — or strip your clothes off and run headlong straight into a fire or active volcano ...)
It's the BEST PROTO-TYPING BOARD EVER!
Here's a few layouts I've done, one or two I've actually built up with a success-rate greater than that of zero for "vero":
More perf layouts than you can shake a stick at that also come with Etchable Layouits, too:
OK I'm convinced, I'll try perf.
I had wanted my grandchildren to call me GrandDad because that's what my dad and his dad and his dad were called. But I tried when my grandson was too young and it just resulted in DDad. Now all the grandnieces and grandnephews call me DDad too! :LOL:
According to the recent research in genetics, circa 2022, it's been found that hereditary stuttering can occur in several generations within a family.
I had a really good post-secondary teacher who stuttered, immense respect for him. Whenever we had a conversation it was extremely difficult to not mimic his stuttering, lest he think I was mocking him. Anyhooo...
SO WATCHA GONNA BUILD? .
I have a list of Boneyard schematics I want to try. There was a thread where Chuck listed some of his favorite circuits, going to pick one of those for some perf board fun. It seems like it might be better than strip boards, no cutting involved.
