Human Amp Driver Organic Overdrive Preamp + Distortion Pedal
manfesto
The Amp Driver has been designed to be the ultimate professional boost, overdrive and distortion device. Using our own custom technology and approach to circuit design, the Amp Driver is a both a high end overdrive and high end preamp in one small box.
The Amp Driver combines the very finest in perfected classic overdrive pedal design with all new tube simulating pre and post overdrive circuit gain stages. These gain stages allow an organic, singing and sustaining tube like boost before your overdrive when the Pre Gain is engaged or a more raw, raunchy and open crunch tone when the Post Gain is driven by the overdrive circuit. Turn both on simultaneously for a unique and beautiful combination of tube like distortion and overdrive tones.”
So, what’re we thinkin?
A modified KoT circuit sandwiched between two boosts?
Or something truly original?
Upvote 2
guessing one of these is probably a mosfet gain stage - SHO?
looks very likely...
im struggling to figure out how you could get "sparkling cleans" without turning off soft and/or hard clipping.
