JFET transistors question
PAGOON
Hello I have noticed on some jfets with the TC1 tester that some look like they are bad and only come up as a resistor (the-ones with the f in the upper left corner). And some come up as a transistor (the central brand CEN) are the f ones any good I’m going with the CENTRAL BRAND ONES FOR NOW. I’ve noticed this with j201 as well
I'd recommend testing your JFETs with a dedicated testing rig (see Run Off Groove method listed on the Fetzer Valve project) for testing JFETs. These inexpensive all-in-one component testers aren't the most accurate (or reliable) way to test a JFET.
Yes, it's very likely your tester that's the issue. Inexpensive testers can't be expected to accurately measure all types of devices.
So I wouldn't toss those "f" JFETs, as they're made by Fairchild. And thus (if they are genuine) there's a very good chance they are excellent.
But if you do decide to get rid of them, please send them my way! ;)
I have a dca55 also and both transistors types act differently is this as well … this is my other tester it was my fathers he passed away when I was 11 I have no idea if it’s even useful … I will checkout the runoff grove method thank you … I was basically wondering why two transistors with the same number but different manufactures acted differently and two different testers and I know that one I first took pictures is a crappy tester. It has its purposes.
You're right, it is strange. One possibility is that the Fairchild device isn't genuine - where did you buy it?
Oh I forget the cheapy one I got on Amazon and i replied to the seller it didn’t do germanium transistors and I was going to return it and he gave me 1/2 the money Back … like 5 dollars and the atlas dca55 from DigiKey. The dca55 picks up the 2n5457 and says it’s a diode with the 2n5457 from guitarpcb and the tayda and Tex mex ones that are cen 2n5457 say drain and source not found..
Theres a theead over on diystompboxes from where the designer of the dca55/75 explains how they test what they test etc.
