Robert Reverse Engineer Nov 16, 2020 #2 Yep. You could use ON/OFF/ON on the distortion and overdrive if you want a "No Clipping" option, although I'm not sure how that would sound on a Rat circuit.
Nostradoomus Well-known member Nov 16, 2020 #3 It sounds pretty good, less gain and more dynamic. It’s a cool option if you’re making a bass tuned version and just want some grit.
Robert Reverse Engineer Nov 16, 2020 #4 Nothing to lose then! It's a bit odd that they didn't opt for a 3-way switch since the running theme was "3" on these...
