SOLVED Kentauride No Sound
joelorigo
The transistors in the photos in the original post are 2SC1815. That orientation looks right to me.
Today I pulled those out, just to see if there was something wonky with them, and inserted 2N3904. I did orient them down and flip 180 degrees.
Doing the audio probe now. Get signal at the T of the IN pad on the PCB. Yay!
Do not get any signal on R1. Get only a crackle sound on C1 and one side of R2 (Section of the schematic included). Have we already found a problem?
Also, I forgot to ask, what do the voltages I posted earlier tell us?
Do you get any continuity, with your DMM, between the in pad and R1?
You say you get crackly sound at C1, put your audio probe there and wiggle stuff around until you find the culprit.
I would suspect the in jack wires first.
Um, does it mean anything that I also get continuity between ground and both sides of D3 & D4, or is that just more of the same short to ground issue?
Probably the same short.
What do you mean about the in jack wires?
Two things
We have a ground bridge somewhere
  1. solder connections on the jack
  2. Input pad
  3. solder bridge between input positive and input ground
  4. Solder bridge between output positive and output ground
We have a Crackly sound
  1. Bad solder joint somewhere
  2. Broken Trace
  3. Lifted pad (have you unsoldered anything?)
to trouble shoot this, put the audio probe wherever it is where you get the crackly sound then start wiggling wires and components until you find the culprit.
