SOLVED Kentauride No Sound
joelorigo
And how does that enter into the fact that there is no sound in bypass?
True bypass is a simple mechanical switching scheme and requires no power to produce bypass signal. If you have no true bypass, it’s a switch issue. If you have no buffered bypass it’s more complicated because the buffer needs power to function in both modes to pass signal.
Some things to consider while cleaning up. The LEDs and their unsecured leads, many pads as mentioned earlier seem unsoldered or cold, the dual gang pot needs insulation from touching the pcb and the neighboring pot pins, and there are a few questionably socketed components. Accurate pinouts and solid contacts are required, especially with round milled sockets. They are finicky and lose effectiveness with re-insertion.
Quick clarification about this topic. There's the 2SC1815 transistors and the 1n34A diodes that are socketed. I double checked the pinout and polarity on them and the seem right. Are you saying that inserting them into the sockets might not have proper connections?
Correct. Sometimes the legs of the component may not make good contact.
It’s just worth checking that everything is seated properly, especially if you have it out of the box and poking around on it.
Hmm, and what to do to eliminate that from being an issue? I think I read on one post somewhere about applying solder to the leads to help it fit more snug. But that may have been for a diode specifically.
You can do that for diodes or transistors. I usually heatsink either when I solder them directly.
You can also kinda kink up the component legs sometimes to help them make better contact in the socket. Don’t know if that makes sense as described lol
Edited to add link about kinking up legs
Post in thread 'Sabbath Distortion issues'
https://forum.pedalpcb.com/threads/sabbath-distortion-issues.14414/post-165905
I have added solder to the above mentioned pots, added solder to a few other spots that maybe looked a little dogey, verified the pinouts on the transistors, and the polarity on the electrolytic capacitors and diodes, and double checked the resistors' and capacitors' values. I also changed the transistors from 2SC1815 to 2N3904 just to see if it had something to do with that. I have verified that the dual pot is floating above the board and not touching any other parts. Still no sound.
Here is the voltages I'm getting:
IC1 JRC4558
1 4.34
2 4.47
3 4.27
4 0
5 4.34
6 4.34
7 4.36
8 8.73
IC2 TL072
1 4.17
2 4.17
3 1.15
4 0
5 4.07
6 4.17
7 4.17
8 8.4
IC3 TL072
1 4.15
2 4.17
3 4.12
4 0
5 4.12
6 4.17
7 4.18
8 16.13
IC3 7660SCPAZ
1 8.4
2 4.33
3 0
4 -3.94
5 -3.78
6 3.76
7 4.78
8 8.39
Q1
C 8.84
B 3.56
E 4.33
Q2
C 8.8
B 2.54
E 2.9
