With the suspect Pots disconnected from the Circuit, If you use a DMM set to Ω & measure across Legs 1 & 3 of you Potentiometers, It should give you the Value of your Pots around 10K.Thanks for the heads up, I desoldered the breakout board. The led issue is solved but I found out that my volume and tone pots are dropped dead. I ordered 2 more to finish the build. I hope it sounds great.
They are dead ?With the suspect Pots disconnected from the Circuit, If you use a DMM set to Ω & measure across Legs 1 & 3 of you Potentiometers, It should give you the Value of your Pots around 10K.
Because they are Linear taper, If you adjust the knob to 1/2 way (50%) you should have around 5K between Leg 1&2, around 5K with between Legs 2&3. If you are not getting any readings, then you Pots are Dead!
Well something good came out of this for me. I’ve got the Kliche Mini on deck and I had no idea about the breakout board not working. I probably would have missed that as well so thanksThanks for the heads up, I desoldered the breakout board. The led issue is solved but I found out that my volume and tone pots are dropped dead. I ordered 2 more to finish the build. I hope it sounds great.
You are welcome. I am still waiting for the pots. I wonder how it sounds. I wish you a merry build.Well something good came out of this for me. I’ve got the Kliche Mini on deck and I had no idea about the breakout board not working. I probably would have missed that as well so thanks
ThanksYou are welcome. I am still waiting for the pots. I wonder how it sounds. I wish you a merry build.
My volume and treble pots were dead. I ordered some and still waiting for them. I’ll desolder those cables and redo them. I couldn’t use pcb mounted because I prepared a 1590bb for this build. I really wonder how it sounds and haven’t played a klon ever. Thanks for your support and help. I’ll update when pots arrive.Also check the wiring for the volume pot. That middle wire (red) looks like it got melted and a chunk of it’s laying on the yellow wire next to it. I’ve learned to save a thousand poroblems by using PCB mounted pots and stopped wiring them unless I absolutely have to for some reason.
Good luck! It’s a great pedal. I’ve built several of them now and sound great!
As long as it’s a latching switch it should work
Like Barry said, if it's latching just wire it up exactly like the diagram in the build docs.Can I use this foot switch and how? Wiring?
Thanks a lot. I’ll try.Like Barry said, if it's latching just wire it up exactly like the diagram in the build docs.
Just ignore the middle column of lugs on the diagram, they aren't used anyway.
