I used alpha potentiometers (pcb mount). These pots have 20% tolerance. I used a W20K (mesured 22,8 K), thats close enough. The C150K pot was a standard alpha pot, I modified it with wire for PCB mounting.What did you use for the W25k and C150k pots? Thanks.
Thank you! Yes, but the fat setting is around 12 o'clock with the C-150K pot. You have to reduce the resistance for that. At 12 o'clock you have already 85% of the total resistance (rev log).Nice work men!!
Can I replace the C150K with a switch for fat sound!
Thanks!!
ThanksDamn! Now that's how it's done!
Thank you!???
That’s immaculate man!!!
Awesome work!!!
Thanks, I got them from a local dealer here in germany. These are vishay dale resistors (cmf-55).Very nice, where did you get those resistors?
Thanks!Super clean!!! Looks Great!
There is no need to use polarizied caps 220n. I've used wima film caps 220n in the tone stack. In my opinion the better choise in this position.I'm building this pedal now. Have a question about what is soldered to A-K. Also the 220n caps, do they have to by polarized?
Awesome! Thanks for the info!There is no need to use polarizied caps 220n. I've used wima film caps 220n in the tone stack. In my opinion the better choise in this position.
Thank you!A-K is anode kathode of your LED, I would stay with the tantalum caps spec'd
