Hello, I finished the low tide with no problems but have played it no more than a few minutes. However I finally got around to playing it for about 15 minutes and although the volume level stays the same the effect gets weaker to barely any effect at all and turning the controls does not help. I did not play it for a few days and tried it again and it worked normally but then as before the effect started to die out. The only change in parts was using a J201 pre soldered SMD board instead of a SKY802 for Q1. I assume the pinout on both transistors are the same. The IC2 was included with the PedalPCB board. I hope it is just the symptom of a bad chip somewhere. I love this playful, whimsical little sound machine. Any help appreciated.
