Low tide template issue
I haven't built the full size Low Tide only the mini but, this looks consistant with other Low Tide builds I've seen on here in terms of footswitch and PCB spacing. I haven't noticed anyone using header pins to connect the two. The builds I've seen, people are using something like the scrap legs cut off of components soldered to their board to connect the switch breakout board and the component PCB.
Here's two examples found in the build reports section:
Idk why i didnt look there. I couldve sworn on my earlier build i used headers… didnt question it.
It would be comical if on your earlier build you drilled the holes incorrectly and were able to use header pins, but on this build you drilled them correctly and were now questioning it. haha
