TravisM
I just finished my first pedal, and everything seems to be working and sounding pretty good. I have lots of gain and volume on tap and the tone stack seems to work as expected as well. I don't have a baseline to judge this specific pedal however.
When I was biasing the transistors, Q5 would only vary between 9.48 and 9.02 VDC at max turns of trim pot 5. I expected that out of Q4, which is connected to the trim pot labeled tone. I validated VCC and ground at each point in the schematic. I also measured each component that I could with a multimeter before installation so I know the trim pot was within spec. I didn't check the JFETs that I bought, but they are the pre-soldered MMBFJ201 JFETs from the store here.
So my questions:
1) Is that an expected result for Q5?
2) Should I care if the pedal is working?
Thanks,
Travis
So my questions:
Thanks,
Travis
