falco_femoralis
Hi all, I'm having trouble getting the modulation LED to work. I've switched around the current limiting resistors a few times and have a feeling I fried a solder pad, but I'm having trouble reading the diagram in order to trace the circuit board. I've played around with the depth control and no matter where it's set the LED doesn't come on.
The diagram says LED2 gets its current from its CLR, which gets its current from the LFO. Where does that come from?
On the diagram there's an LFO in a triangle just after pin 2 of the Depth control. Is this meant to be where LED2 gets its current from?
My board doesn't have continuity between the solder pad of pin 2 of the Depth control and the forward side of the LED2 CLR and I can't check this guess.
Thanks for any direction
