In your place, I would break the trace on IC1.2 between its output (pin 7) and the negative input (pin 6) - then add 100K trimpot between them. Adjust to taste. With pins 7 & 6 connected directly, that portion of the opamp is at unity gain. Adding the trimpot will allow the gain to be increased.
