Not sure where to post, but the dung beetle build doc is not updated to the new revision. A couple of resistor/capacitor values need updatesOkay, there is about to be an influx of new projects...... but I want to tie up any loose ends first.
Is anyone waiting on any missing build docs / schematics? (Not including the most recent releases, those are already on my list)
Would love to get the drill template for the dual effects loop switch.
thanks
Does the Simple Latching Relay Bypass use the same TQ2-L-5V relay as the intelligent version?
+1, would love to get a parts list if nothing elseAny idea when the build docs for the new vibrato will be up?
The docs for the Fuzz Stain do not match the PCB's. My PCB has an additional resistor (1M5) that is neither in the BOM, PCB image, nor the schematic...
I’ve seen elsewhere that the transistor below the 1n5817 is the voltage regulator - L78L12.Few questions on the Electrovibe:
- What are the two pads extra underneath the trimpots? Are these for an option of dropping in 1/4w resistors instead of trimpots?
- What is the top to-92 transistor (dead center, below the 1n5817)?
Figured it was a voltage regulator, thanks! Makes sense that it's 12v with the bulb being 12vI’ve seen elsewhere that the transistor below the 1n5817 is the voltage regulator - L78L12.
I also had a question about the pads on the back of the IC is that so we can use a MAX1044/ICL7660 op amp instead of the LT1054?
That's correct, the solder jumpers on the back are for 1044 / 7660 type charge pumps.I also had a question about the pads on the back of the IC is that so we can use a MAX1044/ICL7660 op amp instead of the LT1054?
I have another dumb question… is the 7371 bulb polarised?? I can’t see any info on a few data sheets I have seen.
