Robert
Reverse Engineer
Any chance for a drilling template/layout for the Recycler?
It's the standard 3-knob template.
Thanks for the update on the drill template, is there a BoM or schematic for the Recycler?
Thank you!
Appreciate the background on the this one. I was clueless. I had never heard of Missing Link Audio, or the ZZ Top pedal but 2 friends with wildly different tastes told me about it so I figured it would be worth checking out.I'll get the schematic (and rest of the build doc) posted asap. The wiring is the standard scheme.
The Recycler is basically a Crunch Box without clipping diodes. (which coincidentally is one of my favorite settings in the Crunch Captain Deluxe)
Thank you very much!!
Bumping for another vote for docs for the Cannon Fodder MKII...actually at this point just a consolidated parts list would be fine.Thank you for the bit of info on the LEDs. I figured as much just with the way the tracing was on the PCB. Any word on the build documents for it and the Cannon Fodder MKII?
Thanks!
Could the cheat sheet BoM for the Danae please be posted? Thanks!
Doesn't it also have two 100uF instead of a 220?I'll get it posted for you in just a bit. The height of the electrolytics is the only difference aside from the male/female pinheaders to attach the PCBs together.
I just populated one of these last night... Luckily I thought to check my electrolytic heightsYes I believe you're correct, although a single 220uF at the correct height would work just as well.
I'll get the list posted as soon as possible.
