jimilee
Naaa, just lay them over.I just populated one of these last night... Luckily I thought to check my electrolytic heights
Of course, everything I have on hand is much too tall
Just checked in for the same request, my boost toggle is killing all sound and something else is off with it, a full build doc and schematic would be super helpful if available.Hey,
Any chance of a Snouse Blackbox schematic?
I'm wanting to build that or a Protein, but would like to see the differences before I make a decision.
Thanks
Frank
Definitely second this request. Mainly for the drill template, I’ve got the board populated.Any ETA on build documentation for the Danae overdrive? (layout, drill template, schematic etc)
How did you populate the Danae board? The PCB image on the website has everything labeled as R1 etc, but I haven't seen a mapping of this back to the parts list.Definitely second this request. Mainly for the drill template, I’ve got the board populated.
The BOM is posted in another thread. And the board itself has the correct components/values on the silkscreen.How did you populate the Danae board? The PCB image on the website has everything labeled as R1 etc, but I haven't seen a mapping of this back to the parts list.
Thanks, I did see the text file, but I'm only seeing component values and quantities, but I don't see what the value of R1, R2, C1 etc if that makes sense.Missing Build Docs / Schematics
Any chance for a drilling template/layout for the Recycler? It's the standard 3-knob template. https://docs.pedalpcb.com/project/drill/125B-3_Knob-Type-1.pdfforum.pedalpcb.com
It’s on this page.
thank you - was looking at preview image before - this fills in the blanks for meThe values are printed directly on the PCB.
This isn't shown in the preview image because revisions sometimes happen before the board is released.
Any electros 50v or less should be ok. You may have to lay them over on their side if you think they might be too tall.Any more build docs for the electrovibe mini? Also having trouble finding short parts - most of the linked parts in the parts list are out of stock...is 8mm diameter too wide for the 100 uF caps?
