neiltheseal
Hey everyone
I'm thinking of making a Simulcast/Duocast but I don't have any germanium transistors and I have a couple of quesitons:
I've had a look around and found the narrowcast. It seems to me that an NPN is in Q2 and VCC/Ground are swapped. If I flipped orientation of Q2 (using a 2n3904) and swapped VCC (going into R7) and ground (r8) then this should work right?
I know I will probably have to mess around with resistors to bias it but to my small brain this seems like it should work.
Thanks in advance.
- Can I use a PNP silicon transistor in place of the germanium one?
- If no to above, can I modify the PCB to accept NPN transistors in q2?
Thanks in advance.
