Modus Operandi Wiring
Lewage
What is the proper wiring for the Modus Operandi Boost? The build docs show 4 eyelets that attach to the foot switch. The board has 6 down there.
Quickly thrown together so I don't leave you hanging all night.
Connect the IN and OUT jack signal and ground wires to the pads at the top of the PCB.
If you have a (PedalPCB) 3PDT Breakout Board the 6 pads at the bottom are a direct pin-to-pin connection between the PCBs.
Otherwise:
