Hello all,
I just assembled a Mofeta Preamp and something weird happens:
The pedal has 6 transistors, 4 2N5457 JFET, and 2 2N5088 BJT.
When I first tested it, the output was ridiculously low even with everything at max, just a mosquito distortion with the tone pots barely affecting the signal, but surely doing something. I tested the resistor values just in case I misplaced something, but everything was ok.
Then I took out the two 2N5088, and, boom, a thunderous sound. Mostly clean with a slight breakup, tube-like, which is nice since I feed it with an octave fuzz, but the eq section was definitely achieving some interesting sounds, and the output was so damn loud past noon. Which is what I was expecting, honestly.
But yeah, now there's nothing where those two transistors are supposed to be, so my questions are:
- What am I missing without those two transistors? Maybe their task is to overdrive both -normal and brite- channels?
- Why is it working? I'm just a hobbyist, I haven't traced the circuit and if I did I won't quite know what's happening there, but leaving "open points" just seem to render some part of the circuit useless. Why does it sound good then?
- Should I try something else? How can I know my 2N5088 transistors are working? I just bought 4, and all of them "misbehave". Would it be dangerous if I flip them over, just in case the pinout for some reason is reversed? Will I blow up my circuit?
Thank you for your feedback.
