More extreme settings for Duo Phase
wrentema
Hi. I'm pretty new here. Just build the Duo-Phase. Absolutely love it.
First test (on drums). Still working on the knobs and layout: https://www.instagram.com/p/CH2uLudlOch/?igshid=1dikoqkjute1q
I was wondering if there would be an easy way to get a bit more extreme results. Especially the feedback knob sounds good but doesn't change the sound that drastically. It could go a bit more wild for my taste :)
Could I change the potentiometer for the feedback from A10K to A100K for example?
Could I change the potentiometer for the depth from B10K to B100K?
Hope to hear from somebody.
Cheers
Cheers
Nice demo.
Changing the pots will not increase the depth or strength of the feedback.
Have you tried increasing the depth by adjusting the trimpots? Turning TR2 CCW should increase the depth. It will go only so far, up to the limits of the LDR's resistance range. Try adjusting TR1 also. The interact, so you'll need to adjust one, then the other, then repeat.
If you want the feedback to be stronger, reduce R7. If you go below 4.7K, it will oscillate when FEEDBACK is dimed.
Have you tried a flanger? They sound great with drums (listen to Bold as Love by Jimi Hendrix) and are much more intense than a phaser.
