Mourguitars
I socketed my Q1-Q3 and picked the pedal up and heard a rattle and one fell out , so i wanted to test to see if they were reading right since they were loose in the sockets, got weird readings , sent this to CDB had me try a few things and wanted me to move it here...
here's what i sent CDB
his reply to check......
Going left to right...
Q1-E This reading makes no sense. Should be 0.6V lower than Q1-B
Q1-B Correct
Q1-C Correct
Q2-E Correct
Q2-B Correct, your meter is loading it down a little.
Q2-C Correct
Q3-D Wrong, should be near 5V, maybe a little lower from meter loading.
Q3-S Wrong, should be 5V (Vref_B)
Q3-G Correct, same voltage as Q2-C
I can't tell you why they are wrong. Dirty board? ( no triple checked ) Short somewhere? (looked every where , none that i see) Verify R3 is 22K. (did ) You can measure it in-circuit, just power off and pull Q1 out of the socket. reading below
R3 is reading 21.7
triple checked board for any flux or shorts....
Mike
Q1-B Correct
Q1-C Correct
Q2-E Correct
Q2-C Correct
R3 is reading 21.7
Mike
