    Read more…
Muzzle Alternate Charge Pump
SuperReverbMan
In the Informant instructions, alternate charge pumps can be used:
"TC1044SCPA or ICL7660SCPA can be used instead of LT1054 by installing a bead of solder across “TC1044” jumper pads on the back of PCB."
The jumper pads exist on my Muzzle v1.5. Can I use a TC1044SCPA on this board after soldering the jumper pads? There's nothing in the instructions about it.
JetFixxxer
By using other than LT1054 does it change the dynamic of the gate? Would you recommend going with the LT1054 and if so what's the reasoning behind it.
falzhobel
Knowing how this pedal is critical to perform well, I'll go with the 1054... I've had 8 that are working fine with the 1054 for now so I don't have plan to change them in the next batch.
