Muzzle key input causing noise
Gbiggs1986
Everything appears to be working on my muzzle except when I turn the pedal off I get a lot of noise( I’m not being funny I know this is a noise gate) it’s very noisy. When I disconnect the key input the noise goes away. When the pedal is engaged it works as it should and everything is dead quiet.
I pulled the key input from the enclosure and sure enough everything works key input no longer causing noise when I disengage pedal. So for some reason when I remove the ground from the key input the noise goes away.
No, the metal sleeve of the jack is making the connection to ground via the enclosure whether you have it wired or not.
You need a jack with a plastic sleeve, something like this:
The product description incorrectly calls it unswitched, but it is switched.
Thanks! I figured it was from the enclosure. I put some electrical tape on both sides and in the hole and it works just fine. I’m going to source a couple nylon washers instead of using a plastic jack.
