Most of the build quality there looks excellent, which makes it even more off-putting that the hole for the screen was not sized properly.View attachment 116703
The OSCIX VSM is a high-fidelity modulation engine inspired by the industrial aesthetic and nostalgic serenity of 80s and 90s analog TV satellite stations. Designed as a "Virtual Sound Modeler," it combines a lush analog-voiced chorus with a real-time waveform monitor.
Key Features:
- Engine: Dedicated "Analog Chorus Engine" with 8 selectable modulation waveforms.
- Visuals: Integrated display showing real-time waveform geometry.
- Depth +: A multi-stage reverb architecture that can be blended for atmospheric textures or used as a standalone effect.
- Shift Function: Paired with Depth + to create expansive, shimmer-like harmonic clouds.
- Vibe Mode: Instant dry-signal kill for pure pitch modulation.
- Warble Control: A dedicated lo-fi parameter designed as a tribute to the pitch-flutter and tracking imperfections of vintage video tapes.
- Eight waveforms:
Sine: Smooth, liquid, and traditional chorus. Sine 3rd: Harmonically enriched modulation. Sweep: Dynamic and sweeping envelope transitions. Lumps: Organic, irregular textures. Random: Unpredictable modulation for unique sonic explorations. Ramp Up: Defined rhythmic growth. Triangle: Classic, symmetrical modulation clarity. Square: Abrupt, rhythmic pitch shifts.- Origin: Conceptually rooted in the telecommunications history of local TV Earth Station.
Not a JHS fan, but I’m genuinely very interested in the ring mod and bit crusher.
What?inspired by the industrial aesthetic and nostalgic serenity of 80s and 90s analog TV satellite stations.
I’m intrigued with the delay
Same. This is the first 3 series (or any other jhs) release that has grabbed my attention.Not a JHS fan, but I’m genuinely very interested in the ring mod and bit crusher.
The pedals or the inevitable pcbs?Same. This is the first 3 series (or any other jhs) release that has grabbed my attention.
No tap tempo? Fucking lameView attachment 116701
Walrus Audio Highpoint Compressor
Personally feel like it’s the Mira with some fancy packaging and a metering system; but it would look nice next to the Mantlewww.talkbass.com
I still say, if you add tap tempo to a compressor, it becomes a tremolo.No tap tempo? Fucking lame
Doesn’t it depend on what parameter is being tempo-controlled? Ratio could be potentially interesting. I guess it would be worth playing around with some automation in a DAW to try it out now that I think about it.I still say, if you add tap tempo to a compressor, it becomes a tremolo.
Is there a dark corner somewhere plundered eeprom's get flipped?I'd be willing to bet all three are FV-1 based (and the same PCB).
I think that would be illegal.Is there a dark corner somewhere plundered eeprom's get flipped?![]()
To be honest, my first thought was "Which Hammertone pedal is this based on?", but that might not be totally fair.
