Laundryroom David
Keyboard Cowboy 🤠
Took the words right outta m’mouthOh, I like Jeff![]()
When I'm designing a layout for an amp I always keep the preamp tubes at least 2" away from each other. Of course this is hundreds of volts, but the "coronal effect" is real. Run away oscillation is a b***h......Yeah I'm a little nervous. Like on the one hand I'm confident in Jeff's abilities, but on the other hand I've had intense battles making high-gain tube circuits play nicely in pedal formats. Boards have been ordered, so we'll see what happens when they come in a couple weeks.
Miniaturizing a fusion reactor is not an easy task.I sincerely doubt this is corona effect. At the frequencies this circuit operates at we're way below the corona inception voltage. I assume it's simple parasitic capacitance and crosstalk of sensitive high gain lines. Care was taken to reduce it, but this is an extremely high gain circuit, and maybe the distance between the traces just isn't enough.
I don't know if you guys are just fucking with the rest of us non-EEs now lolwe're way below the corona inception voltage
Me either, but I know what the name of my next prog metal band is going to be!I don't know if you guys are just fucking with the rest of us non-EEs now lol
Anything with ''Corona'' tagged to it sounds unhealthy!!!I don't know if you guys are just fucking with the rest of us non-EEs now lol
It's basically where high voltage lines (most commonly AC transmission lines) are running so high that they start to reach the dielectric breakdown voltage of the air (the same inherent thing that causes static shocks and voltage arcs), causing what looks like a glowing (corona) around the line. It's typically in the kV range, but the higher the frequency of the signal, the lower the voltage needed for it to happen. So with 350V being the max voltage found anywhere in the circuit and all of our signals at that voltage being low frequency, it's unlikely to happen in something like this.I don't know if you guys are just fucking with the rest of us non-EEs now lol
EVEN CERVEZA?Anything with ''Corona'' tagged to it sounds unhealthy!!!
On the 5e3 I had that exhibited this, it would kick in at around 60% volume. The wire leading to v2 was the culprit presumably feeding back into the more sensitive first stage. In one position there would be a perfect signal on the scope, then you could move the wire (chopsticks) and watch it go into a box full of squiggly lines. I found that by moving this wire, you could actually change the breakup of the amp.I sincerely doubt this is corona effect. At the frequencies this circuit operates at we're way below the corona inception voltage. I assume it's simple parasitic capacitance and crosstalk of sensitive high gain lines. Care was taken to reduce it, but this is an extremely high gain circuit, and maybe the distance between the traces just isn't enough.
You can use this forum while you are at work, its ok. This forum doesnt count as social media. I strongly disagree with all conventional social media in the workplace. but this forum is something different entirely. plus, what else are you gonna do on your breaks at work?That's because I don't use social media while I'm at work, loser.
This forum has Like buttons. I think that makes it social mediaYou can use this forum while you are at work, its ok. This forum doesnt count as social media. I strongly disagree with all conventional social media in the workplace. but this forum is something different entirely. plus, what else are you gonna do on your breaks at work?
My brother’s name is spelled Jeffry. My mom swears that it’s because she and dad liked the sound of the name but didnt know how to spell it.I'm a Jeffrey and I have never met a Jeffery. I've decided that it's just how a quarter of all people THINK it's spelled. I have absolutely nothing to back this claim. Do Jefferies pronounce it with 3 syllables?
