LoserLazer
Hello everyone,
I completed my build of the VHS pedal and the reverb effect does not work. I suspect I have a bad eeprom but was wondering if there were any other troubleshooting steps I should take.
Audio passes through the board just fine, the switches turn the effects on and off, and the volume and chorus effects work.
Turning the pot of the reverb channel makes no change to the sound.
I verified the FV-1 chip was working by grounding pin 13. This gave the reverb pot some sort of pitch modulation.
The eeprom chip IC2 is getting the right voltage and has continuity to the FV-1.
Is there anything else I should try?
