This is an option you could add to almost any PCB, theoretically.I like to run time domain effects (reverb and delay) post amp in stereo and route back into mixer.
Guitar -> mono pedals -> amp -> OX BOX -> stereo time pedals -> mixer
It would be cool if there were balanced TRS inputs or low impedance XLR inputs ... maybe?
Definitely would like a balanced stereo I/O option for use on not-guitars. -And a MIDI in option for syncing loopers or WHATEVERIt would be awesome to have the option on the PCB to build with TRS or dual TS in/outs. When running non-1/4” stereo gear thru pedals I prefer to pop an adapter on a 1/8” cable than find the right Y cable.
I have transformers for plugging in microphones and what not into pedals. However, I was more interested in having balanced ouputs (i.e., inverted signals sent down the line) due to the noise reduction that happens with them.This is an option you could add to almost any PCB, theoretically.
The audio inputs into the Daisy ADC are "unbalanced" regardless so all you need, at a minimum, is a lo-Z to hi-Z matching transformer to combine your 3 wire signal to a 2 wire signal (and the reverse for output). Superb transformers (i.e. Jensen JT-DB-EPC) would be ideal but are rather expensive. In practice this is not realllllly necessary and you can easily use far less expensive transformers (like the ones I ripped out of some old Radio Shack 1/4"-XLR adapters) at the input side and then another on the output side, or add an active circuit to output line level. The only issue there is headroom so you couldn't blast a cheap transformer with a 20volt boost pedal without extra distortion, which may sound extra great or not. Now... if you're planning on using a microphone at the input you'd likely want to add another gain stage there for obvious reasons.
SO, you'd be customizing your build, but that's OK.
Any news on that? I would be quite interested!
Fantastic! Once again hoping MIDI is implementedNah, it'll still happen.
Just been focused on other projects for a while.
Can't wait to see it happenNah, it'll still happen.
I could be misunderstanding, but I believe the underlying issue is with the seed hardware itself (specifically, the codec(s) supported by the chips used on the Seed). Folks have tried modifying the Terrarium circuit to work around the noise issue, but it doesn't look promising.Ive come accross some of the daisy seed noise threads both here and in electrosmith forum (rev5 and rev7 boards). Is this something that could be worked around in upgraded version of the Terrarium board ?
Oh ok, thks for the clarification about the workarounds.I could be misunderstanding, but I believe the underlying issue is with the seed hardware itself (specifically, the codec(s) supported by the chips used on the Seed). Folks have tried modifying the Terrarium circuit to work around the noise issue, but it doesn't look promising.
I have a rev5 board in my stash and have been procrastinating on building or this very reason. It was suggested elsewhere that you could treat it as a DI-only box, which I might try out soon.
This was my understanding of the issue as well. The first chip they designed around became unavailable and everything else was not as good. They tried another chip for a couple of revisions and then landed on a slightly better chip but not as good as the first.I could be misunderstanding, but I believe the underlying issue is with the seed hardware itself (specifically, the codec(s) supported by the chips used on the Seed).
