PCB Numbers
Strat68
Is there anyway to look up the name of a pcb by the number on the bottom of the board? I have a few abandoned projects from years ago I may try to resurrect.
The behavior has always been a little wonky.... you had to type in the PCB### then not hit enter and the results pop up.
I patched it when this thread came up, it should search when hitting enter now.
Thanks Robert. I was also most likely using a space before the number.
