Has anyone tried this and got good results?
Very few clones of mutron out there. Would’ve loved if PP carried it.
I used 5089 and 87Just checked kraken and it does use 5088s. AFAI can see the circuit in context of the NPN is identical except kraken uses ca3080. And the replacement 16pin 13700n is indeed the selling point for pcbguitarmania. I wonder if the Vb generated using 5088 is different then 5089.
There is a voltage map here on pg13. At least I can compare some of them with mine.
@Diynot what transistors did you use for your build?
Yes, I’ve twice. I think I’m pretty sure about that.So just to be sure, you have gone through and verified your resistor/cap values, correct?
Maybe the higher gain of the 5089 is needed to open the envelope?Yes, I’ve twice. I think I’m pretty sure about that.
I’m thinking based on @Gordo comments and the fact you’re following BOM as well, it’s very clear that I’m off-base here. Just ordered 5089s. I’ll keep you all posted.
Too bad you gave them more moneySome update:
I tried new 5089 from digikey. Same issue. No effect. So I ordered a new pcb from pcbguitarmania, since I was building this for a good friend’s bassist and my enclosure labels matched it.
Pcbguitarmania takes forever to fulfill orders - either he is shipping 1k units a day or … anyways, the new one isn’t shipped yet so I had time to debug. Decided to perform a full connectivity check.
Found a clear missing link from R12 to the Range pot. Never ever have I found this on ppcb or other sites. Not sure if missing connects are normal. I hope not.. coz they’re painful to find.
Shorted that link and it works! 5088 works as well. The NTE equivalent transistors work too. Have to say the effect circuit is absolutely fun! I’m glad it sounded so good after all this bs.
Now I’m sitting on bunch of 5089s, 13700N and extra pcb of vutron…
For the last time. I was desperate to not make another enclosure. Madbeans labels are flipped. Lots of lessons learned here.Too bad you gave them more money
That's worth something though. And you got your first board working. Nice workLots of lessons learned here.
I was wondering about that. I know lovepedal uses 5089s quite a lot. Some Ross compressor clones use 13700n and some other filter circuits.Not a bad place to be sitting, plenty of circuits out there to use the 5089s and 13700s in
Trust me I’ve asked him. He is well aware of my (painful) journey of vutron. He has been responsive throughout… although with absolutely zero productive suggestions. He responded to my email detailing the issue with a “maybe a factory issue of your PCB”.If you tell PCBGuitarMania you have an issue with the board, he'll likely send you the new one for free or give you a store credit (though you may not want another PCB from PCBGM).
Looking through my past build docs, these are projects I’ve built that use an lm13700 (plus or minus a ton more parts:I was wondering about that. I know lovepedal uses 5089s quite a lot. Some Ross compressor clones use 13700n and some other filter circuits.
I’m not much of a filter guy. This bruised and battered vutron will serve me well for a long time. If you’ve any other suggestions please let me know.
