This is a the Mini Me from Guitar PCB, a Small Clone clone. When I finished it yesterday it worked. Today it doesn't pass any signal in bypass or when engaged. Seems like all the wiring connections are still connected.
Ah that seems to have been it, thank you. I rotated it away from the enclosure and it’s working.
That however made the tip of the jack dangerously close to touching that chip in the upper left. I have inserted a piece of plastic to separate the legs of the chip from the tip of the jack. Is that a good idea, is it necessary?
A cold solder joint can work and then fail at some point?
I built it bit by bit over a couple of days. When I was done and verified that it was working, I took it out of the enclosure, added the decal and some clear coat, and put it back in the enclosure. Which was yesterday, and then I checked it again and it worked.
