photon vibe dead circuit
i built the photon vibe recently..plenty signal when disengaged,
led engaged light comes on, but...
1) no signal when engaged..
2) photon lamp lights but does not pulse..
i have built about 10 or so pedals..i am good at soldering, and i have done a ton of homework..im not super great at troubleshooting...HELP!!! i need somebody, help! not just anybody...wont you please, pleeeease help me, help me help meeeeeeee....oooooooo.
16023708009886734849556239748261.jpg wish i could send video....its doin some weird shit...the lamp pulses a few times when you turn the depth knob then stops...then when you turn the speed knob it come on...gets brighter, goes out...randomly....
close up looks like possible solder bridge, but its just light reflecting off residual rosin...i clean it off w alcohol, but there are little/micro lumps left here and there...but not any solder that i can see
Just prise it forward carefully and try to jam something non conductive in there something the solder joints wont stick through, cardboard maybe
k...last report on this pedal issue..
1) now getting engaged signal
volume works
hi/lo pots work (nice sounding pre)
2) lamp does NOT pulse, neither the speed nor depth seem to have any effect...
all three trims are correct value and work...
Probably cracked pot or pad, When 6 points that close being soldered, It's not a good idea to lift or lever!
Do you have another Dual C100, Just cut the Legs individually & remove old pot 1 Leg at a time from PCB.
Also, cut lead end go through electrical tape pretty easily. If you are removing the pot, then I would use the thick foam tape, or get one of the pot insulator PCBs that pedal PCB sells.
Easy enough to continuity check it to see if it's still connected to the pads touch one probe to the actual pot lug and the other to the pad if you've got clip ends for your probes even better clip it on turn it over and touch the pad see if it's connected
You may also be able to check to see if it's still shorting on anything probe the metal body of the pot then probe component legs on the other side in that area, no easy task though!
The other solution as mentioned is to snip off as much of the pot lug ends and desolder it, If it's something difficult like a dual pot I use a solder sucker and apply flux so it melts easier then just wire it back on
As I said initially you wanted something that the solder joints wouldn't stick through
I should have been more precise, something thin and rigid like an old piece of credit card or a thin guitar pick that kinda thing, you'd need to make sure it's non conductive with your meter obviously
